Introducción
A watch's battery is responsible for maintaining the life-time of the watch. Therefore, a damaged battery will take away from the enjoyment of the watch. This guide highlights the steps required to replace the Huawei Jewel Battery. It can be a relatively difficult process, so follow all steps carefully.
Qué necesitas
Begin by laying the watch on a flat, smooth surface.
Obtain a Flex Extension with a Size 1.0 mm flat-head. In the case of not having said tool, for this model of watch one can use the hands to replace the strap.
Locate the 4 T3 screws in the back of your watch, and use the T3 Torx Screwdriver to unscrew them.
Herramienta utilizada en este paso:iFixit Opening Picks (Set of 6)$4.99
Use the spudger or opening pick to carefully lift the battery from the watch.
19 personas más completaron esta guía.
8 comentarios
Any idea where one can purchase the actual battery? I can’t find one anywhere.
@Chris wellings: i was able to find one on ebay. Arrived quite quickly. And you definitely need a T2(not 3) screwdriver to open up the watch.
Also found one on eBay. I was replacing the battery on the standard Huawei Watch (W1) and this guide was really helpful.
