Saltar al contenido principal
Huawei Pronto LTE Display Screen Assembly Replacement
Qué necesitas
  1. Huawei Pronto LTE Display Screen Assembly Replacement, Battery: paso 1, imagen 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Battery: paso 1, imagen 2 de 2
    • Remove the back cover of your Huawei Pronto LTE using an opening tool.
    • Lift the back cover off of the device after the four corners are unlatched.
  2. Huawei Pronto LTE Display Screen Assembly Replacement: paso 2, imagen 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 2, imagen 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 2, imagen 3 de 3
    • Remove the 15 screws on the back of the device using a Phillips #000 screwdriver.
    • Hold the device in place while you are doing this step.
    • Lift the inner cover gently by using a spudger.
  3. Huawei Pronto LTE Display Screen Assembly Replacement: paso 3, imagen 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 3, imagen 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 3, imagen 3 de 3
    • Detach the yellow latches along the sides to remove the motherboard.
  4. Huawei Pronto LTE Display Screen Assembly Replacement: paso 4, imagen 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 4, imagen 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 4, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Ensure that all latches are detached and that there are no extra screws to avoid damaging the motherboard.
    • Use tweezers to gently remove the motherboard from the device.
  5. Huawei Pronto LTE Display Screen Assembly Replacement: paso 5, imagen 1 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 5, imagen 2 de 3 Huawei Pronto LTE Display Screen Assembly Replacement: paso 5, imagen 3 de 3
    • The battery should be revealed once the motherboard is removed.
    • Lift the battery from the top left corner.
  6. Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: paso 6, imagen 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement, Screen Assembly: paso 6, imagen 2 de 2
    • Remove the motherboard. Refer to the Motherboard Replacement Guide.
    • Remove the battery.
  7. Huawei Pronto LTE Display Screen Assembly Replacement: paso 7, imagen 1 de 2 Huawei Pronto LTE Display Screen Assembly Replacement: paso 7, imagen 2 de 2
    • Once the battery is removed the screen will be visible.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 6
Todo El Tiempo: 91
