Saltar al contenido principal
Introducción
The battery is an essential component for the phones ability to function. This guide will clearly show you how to remove the battery without damaging other parts of the phone. Before you start please have the correct tools listed underneath as these tools will ensure a successful battery replacement.
  1. Begin to lever up the back cover of your Huawei Pronto LTE, using an Opening Tool. If you are experiencing difficulties with removing the cover, use the metal spudger. Once all corners of the cover are levered, gently lift the back cover off.
    • Begin to lever up the back cover of your Huawei Pronto LTE, using an Opening Tool.
    • If you are experiencing difficulties with removing the cover, use the metal spudger.
    • Once all corners of the cover are levered, gently lift the back cover off.
  2. Unscrew all 15 screws on the back of the phone using the #000 Phillips head screwdriver, and remove the rear frame. Make sure to hold down the phone. Gently lift the inner cover using the metal spudger.
    • Unscrew all 15 screws on the back of the phone using the #000 Phillips head screwdriver, and remove the rear frame.
    • Make sure to hold down the phone.
    • Gently lift the inner cover using the metal spudger.
  3. Kits de Reparación de Android
    Estás a un kit de tu nueva pantalla o batería.
    Comprar Ahora
    Comprar Ahora
  4. Detach the yellow latches along the sides to remove the motherboard. Detach the yellow latches along the sides to remove the motherboard. Detach the yellow latches along the sides to remove the motherboard.
    • Detach the yellow latches along the sides to remove the motherboard.
  5. Make sure all latches are detached and that there are no extra screws, to ensure safe removal of the motherboard. Gently remove the motherboard from the device with the tweezers. Gently remove the motherboard from the device with the tweezers.
    • Make sure all latches are detached and that there are no extra screws, to ensure safe removal of the motherboard.
    • Gently remove the motherboard from the device with the tweezers.
  6. Once the motherboard is removed there should be nothing in the way of the battery. Lift the battery from the top left corner. Lift the battery from the top left corner.
    • Once the motherboard is removed there should be nothing in the way of the battery.
    • Lift the battery from the top left corner.
Conclusión
Crystal Edwards
Miembro Desde 21/09/18
255 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 183
