Saltar al contenido principal
Huawei Phone p7 Back Cover Replacement
Qué necesitas
  1. Huawei Phone p7 Back Cover Replacement, Back Cover: paso 1, imagen 1 de 1
    • Heat to melt the adhesive sticker under the back cover.
  2. Huawei Phone p7 Back Cover Replacement: paso 2, imagen 1 de 1
    • Place the suction cup and pull to open a gap between the back cover and the body.And then insert into the guitar pick and slide to cut the sticker.
    • Attention: Be careful with the bottom side because there is the battery flex cable.
  3. Huawei Phone p7 Back Cover Replacement: paso 3, imagen 1 de 1
    • Remove the back cover.
  4. Huawei Phone p7 Back Cover Replacement: paso 4, imagen 1 de 1
    • And you can replace with the new back cover.
Conclusión
10 personas más completaron esta guía.
Sophia
Miembro Desde 03/25/14
43,810 Reputación
62 Guías creadas
Un comentario
Is the nfc sensor in the back plate, because i broke the glass and i can see some antennas through the holes. And i think the exposure killed my nfc.
Yoran - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 11,514
