Introducción
Use this guide to remove and replace the complete display with the frame of a Huawei P9 Plus.
Qué necesitas
Remove the sticker that sits on top of the left screw above the battery.
Remove the three Phillips #00 screws that hold the metal plates in place.
Use a tweezer to remove the sticker that sits on top of the screw next to the antenna cable.
Unplug the antenna cable and release it from the bracket on the metal plate covering the main flex cable.
Remove the four Phillips #00 screws.
Use a tweezer to loosen the vibration motor flex cable. Be careful since it is a little bit sticky.
Remove the vibration motor.
Use a tweezer to unplug the antenna cable and remove it.
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where necessary after removing any residue.
7 personas más completaron esta guía.
6 comentarios
Can you do with the Camera replacement and where to buy it? Thank you in Advance.
do you sell huawei p9 32gb mainboard?
Hat super geklappt, aber ein kleines Plastikteil war nicht mit in der Anleitung: https://imgur.com/a/SFYVXnE
Worked perfectly, but a small piece of plastic was missing in the instructions: https://imgur.com/a/SFYVXnE
Thanks for the note. Added it as an example for the check old and new part for missing components)
