Saltar al contenido principal
Huawei P9 Charging Board Replacement
Qué necesitas
  1. Huawei P9 Charging Board Replacement, Back Cover: paso 1, imagen 1 de 3 Huawei P9 Charging Board Replacement, Back Cover: paso 1, imagen 2 de 3 Huawei P9 Charging Board Replacement, Back Cover: paso 1, imagen 3 de 3
    • First switch off your phone and remove the SIM card tray.
    • Unscrew the two Pentalobe P2 screws located at the bottom next to the device's USB C port.
    • If the screen is cracked you might want to use some tape to protect your eyes from glass shreds and get a better grip to open the phone.
  2. Huawei P9 Charging Board Replacement: paso 2, imagen 1 de 2 Huawei P9 Charging Board Replacement: paso 2, imagen 2 de 2
    • Avoid to lift only the display instead of the whole phone assembly as doing so may cause damage to the screen.
    • Use an iSclack or a suction handle to separate the phone assembly from the rear panel.
    • In case you can‘t manage to lift the phone assembly out of the rear panel you can insert the pointed end of a spudger in the headphone jack opening and press the phone assembly upwards until you create a gap between assembly and rear panel. Then use the spudger to lever the phone assembly out of the panel.
    • Don't remove the rear panel completely yet. There is a cable connected to it! It is running from the finger print sensor to the display unit.
  3. Huawei P9 Charging Board Replacement, Fingerprint sensor: paso 3, imagen 1 de 2 Huawei P9 Charging Board Replacement, Fingerprint sensor: paso 3, imagen 2 de 2
    • Disconnect the fingerprint sensor using a spudger.
  4. Huawei P9 Charging Board Replacement, lower section: paso 4, imagen 1 de 3 Huawei P9 Charging Board Replacement, lower section: paso 4, imagen 2 de 3 Huawei P9 Charging Board Replacement, lower section: paso 4, imagen 3 de 3
    • Undo the three Phillips #00 screws.
    • Disconnect the loudspeaker flex connector.
    • Carefully remove the metal bracket.
    • Mind the adhesive underneath that might stick to the headphone connector.
  5. Huawei P9 Charging Board Replacement: paso 5, imagen 1 de 3 Huawei P9 Charging Board Replacement: paso 5, imagen 2 de 3 Huawei P9 Charging Board Replacement: paso 5, imagen 3 de 3
    • Disconnect the motherboard flex cable and the antenna cable.
    • Unplug the headphone jack connector.
  6. Huawei P9 Charging Board Replacement, Charging Board: paso 6, imagen 1 de 1
    • Now you can easily remove the charging board.
Conclusión
8 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 11/23/16
202,809 Reputación
682 Guías creadas
Equipo
iFixit Miembro de iFixit
Staff
135 Miembros
16,732 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 7,127
