Saltar al contenido principal
Introducción
null
Partes
No se especificaron partes.
  1. Heat the backglass with a heat gun. Use a suction cup and a card to gently remove the back glass. Don't hesitate to heath again if there is any resistance.
    • Heat the backglass with a heat gun.
    • Use a suction cup and a card to gently remove the back glass.
    • Don't hesitate to heath again if there is any resistance.
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Disconnect the fingerprint cable. You have to open the lock of the cable on the back glass. You have to open the lock of the cable on the back glass.
    • Disconnect the fingerprint cable.
    • You have to open the lock of the cable on the back glass.
  4. Use the heat-gun to heat the fingerprint. Push the fingerprint to remove it from the backglass It's done.
    • Use the heat-gun to heat the fingerprint.
    • Push the fingerprint to remove it from the backglass
    • It's done.
Conclusión
2 personas más completaron esta guía.
Skyphone
Miembro Desde 05/07/13
324 Reputación
2 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 25
Últimos 30 Días: 135
Todo El Tiempo: 1,588
