Saltar al contenido principal
Huawei P20 Camera Lens Replacement
Qué necesitas
    • If you have any questions, feel free to ask them!
Conclusión
5 personas más completaron esta guía.
Pieter
Miembro Desde 11/10/15
494 Reputación
1 Guía escrita
5 comentarios
Thanks, you helpt me well with this one!
Kristof Ven - Contestar
Did this step by step, making sure not to touch the lense. Although, quality of photos are worse than before for some reason
Cole VHelm - Contestar
Maybe the new lens is of a lower quality?
Pieter -
My lens hasn't broken it just has a smudge on the inside, can you do this and then use the same glue to put the lens back on. Or do you still recommend replacing the entire lens?
Luke Hardy - Contestar
Hi Luke, Sorry for the late response. I had not seen your reply. It’s definitely going to be hard if you want to remove the glass in one piece.
Please let us know if it worked out for you. Good luck
Pieter -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 20
Todo El Tiempo: 10,197
