Introducción
Use this guide to disconnect the battery in your Huawei P10 smartphone.
Qué necesitas
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Remove the Phillips #00 screw.
Use tweezers to remove the metal plate.
Use a spudger to disconnect the battery flex cable.
Casi Terminas!
To reassemble your device, follow these instructions in reverse order. Reapply adhesive where it is necessary.
Conclusión
