Introducción
In this guide we show you how to replace the vibration motor in your Huawei P10 Plus smartphone.
Qué necesitas
Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
Remove the 13 Phillips #00 screws.
Remove the metal shield which holds down the display flex connector.
Remove the three Phillips #000 screw.
Remove the metal shield covering the charging board with tweezers.
Use an iOpener to loosen the adhesive beneath the vibration motor.
Remove the vibration motor.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
