Saltar al contenido principal
Introducción
Use this guide to replace the loudspeaker in your Huawei P10 smartphone. When reassembling your phone apply new adhesive where it is necessary.
  1. Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. Getting the prying tool in  will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Kits de Reparación de Android
    A new screen or battery is one kit away.
    Comprar Ahora
    Comprar Ahora
  5. Remove the Phillips #00 screw. Use tweezers to remove the metal plate. Use a spudger to disconnect the battery flex cable.
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  6. Remove the four Phillips #00 screws. Use Tweezers to remove the metal plate.
    • Remove the four Phillips #00 screws.
    • Use Tweezers to remove the metal plate.
  7. Use a spudger to disconnect the main flex cable. Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
    • Use a spudger to disconnect the main flex cable.
    • Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
  8. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables. Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
    • Use a spudger to disconnect the headphone jack and the loudspeaker flex cables.
  9. Do not damage any components sitting on the charging board while removing it. Use a spudger to pry out the charging board.
    • Do not damage any components sitting on the charging board while removing it.
    • Use a spudger to pry out the charging board.
    • Remove the charging board.
  10. Only insert the spudger as deep as 1/16 of an inch to avoid damage. Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can  use an iOpener to loosen it.
    • Only insert the spudger as deep as 1/16 of an inch to avoid damage.
    • Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
    • Remove the loudspeaker.
    • When reassembling your phone, apply new adhesive where it's necessary.
Conclusión
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Una persona más ha completado esta guía.
Dominik Schnabelrauch
Miembro Desde 23/11/16
44,427 Reputación
223 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
105 Miembros
9,280 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 6
Últimos 7 Días: 26
Últimos 30 Días: 99
Todo El Tiempo: 1,399
