Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Introducción
Use this guide to replace the back cover of your Huawei P10 Lite.
  1. Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive. Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in. If the adhesive is hard to cut, use an iOpener to loosen it.
    • Insert the tip of an opening pick between the back cover and the mid frame and slide it around the phone, to cut the adhesive.
    • Using a suction handle to lift the back cover may help to get an initial gap for the opening pick to put in.
    • If the adhesive is hard to cut, use an iOpener to loosen it.
  2. After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone. Flip the rear cover over to the right side of the phone. Flip the rear cover over to the right side of the phone.
    • After you cut the adhesive on every edge, twist your opening pick, to separate the rear cover from the phone.
    • Flip the rear cover over to the right side of the phone.
  3. Kits para Nintendo Switch
    Una solución rápida para volver al juego
    Comprar kits de Switch
  4. Use a pair of tweezers to remove the sticker. Remove the two Phillips #00 screws.
    • Use a pair of tweezers to remove the sticker.
    • Remove the two Phillips #00 screws.
    • Remove the four 2.5 mm Phillips #00 screws.
  5. Use tweezers to remove the mainboard shield. Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • Use tweezers to remove the mainboard shield.
    • Use the flat end of a spudger to disconnect the finger print sensor flex cable.
    • When reassembling apply new adhesive where it is necessary.
Conclusión
14 personas más completaron esta guía.
Dominik Schnabelrauch
Miembro Desde 23/11/16
63,189 Reputación
290 Guías creadas
Equipo
iFixit Miembro de iFixit
Community
124 Miembros
11,602 Guías creadas
Great guide, but how do I move the fingerprint sensor to the new cover?
mela ross - Contestar
What adhesive should I use? Thank you!
Calin GV - Contestar
Nice guide! Thanks! I got a little question about the coloring of the back panel. What kind of coloring is it? Is it a coating you can take off, or is it more like a layer of paint you can scrape off? I am wondering, because I want to clear the back of my Huawei P10 lite. I hope it’s possible though.
Daan - Contestar
Can you send me please back cover.
I'm from Nepal .
Md Usman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 22
Ultimos 7 días: 171
Ultimos 30 días: 796
Todo El Tiempo: 24,940
