Saltar al contenido principal
Huawei MediaPad S7-301u Screen Replacement
Qué necesitas
  1. Huawei MediaPad S7-301u Screen Replacement, Battery: paso 1, imagen 1 de 3 Huawei MediaPad S7-301u Screen Replacement, Battery: paso 1, imagen 2 de 3 Huawei MediaPad S7-301u Screen Replacement, Battery: paso 1, imagen 3 de 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Screen Replacement: paso 2, imagen 1 de 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Screen Replacement: paso 3, imagen 1 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 3, imagen 2 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 3, imagen 3 de 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Screen Replacement: paso 4, imagen 1 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 4, imagen 2 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 4, imagen 3 de 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
  5. Huawei MediaPad S7-301u Screen Replacement, Motherboard: paso 5, imagen 1 de 3 Huawei MediaPad S7-301u Screen Replacement, Motherboard: paso 5, imagen 2 de 3 Huawei MediaPad S7-301u Screen Replacement, Motherboard: paso 5, imagen 3 de 3
    • Once the battery is removed, the motherboard is ready to be removed.
    • Remove the camera from the motherboard by disconnecting the clip next to it. You can use the precision tweezer here.
    • To remove the power port from the motherboard, unscrew the two 4mm screws with a T5 bit.
  6. Huawei MediaPad S7-301u Screen Replacement: paso 6, imagen 1 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 6, imagen 2 de 3 Huawei MediaPad S7-301u Screen Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Use the precision tweezers to disconnect the 7 clips from the motherboard
    • Remove the headphone input cable from the motherboard by carefully pulling on the clip.
  7. Huawei MediaPad S7-301u Screen Replacement: paso 7, imagen 1 de 2 Huawei MediaPad S7-301u Screen Replacement: paso 7, imagen 2 de 2
    • Unscrew the 4 screws 4mm with T5 bit from the edges or the frame of the motherboard to remove it
    • Carefully remove the motherboard from the metal frame.
    • A long thin tape will be attached to the motherboard. This tape can be pulled along with the motherboard.
  8. Huawei MediaPad S7-301u Screen Replacement, Screen: paso 8, imagen 1 de 1
    • Remove the 7 2mm screws for on the metal frame. Use a J000 screwdriver.
  9. Huawei MediaPad S7-301u Screen Replacement: paso 9, imagen 1 de 2 Huawei MediaPad S7-301u Screen Replacement: paso 9, imagen 2 de 2
    • Carefully remove the LCD from the front glass casing.
    • While separating the LCD from the device, be careful not to introduce any debris.
Conclusión
3 personas más completaron esta guía.
Miguel Lugo
Miembro Desde 09/26/17
598 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G5, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 17
Todo El Tiempo: 2,518
