Saltar al contenido principal
Huawei MediaPad S7-301u Battery Replacement
Qué necesitas
  1. Huawei MediaPad S7-301u Battery Replacement, Battery: paso 1, imagen 1 de 3 Huawei MediaPad S7-301u Battery Replacement, Battery: paso 1, imagen 2 de 3 Huawei MediaPad S7-301u Battery Replacement, Battery: paso 1, imagen 3 de 3
    • Use either your finger or a metal spudger to lift both the top and bottom black covers on the back of the tablet.
  2. Huawei MediaPad S7-301u Battery Replacement: paso 2, imagen 1 de 1
    • Use a Phillips (J000) bit screwdriver to remove the 6 (2 mm) screws located at the top and bottom of the tablet.
  3. Huawei MediaPad S7-301u Battery Replacement: paso 3, imagen 1 de 3 Huawei MediaPad S7-301u Battery Replacement: paso 3, imagen 2 de 3 Huawei MediaPad S7-301u Battery Replacement: paso 3, imagen 3 de 3
    • Hold the device by the silver edge and the front of the screen.
    • Then use your other hand to push gently on the center back of the tablet until the front screen is detached from the silver back cover.
    • Finally, separate the screen from the silver back casing.
  4. Huawei MediaPad S7-301u Battery Replacement: paso 4, imagen 1 de 3 Huawei MediaPad S7-301u Battery Replacement: paso 4, imagen 2 de 3 Huawei MediaPad S7-301u Battery Replacement: paso 4, imagen 3 de 3
    • Use the plastic spudger to remove the battery from the device that is glued on the metal frame.
    • Be careful not to puncture the battery while removing it.
    • Follow the wires to where they are connected on the motherboard and simply pull the white connector out of the socket.
    • When removing the battery, be careful with the connector that attaches the wires to the motherboard.
Conclusión
5 personas más completaron esta guía.
Miguel Lugo
Miembro Desde 09/26/17
598 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S11-G5, Passmore Fall 2017 Miembro de USF Tampa, Team S11-G5, Passmore Fall 2017
USFT-PASSMORE-F17S11G5
4 Miembros
8 Guías creadas
Un comentario
Thanks Miguel. Worked worked perfectly. My generationally challenged but still handy Mediapad is returned to service.
cheers,
Marcus
marcusinho_ab - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 7,016
