Saltar al contenido principal
Repara tus cosas
Derecho a Reparar
Partes y herramientas
Introducción
Use this guide to help you replace a broken or malfunctioning rear and front camera. Ensure that you have all the proper tools before starting.
  1. Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool. Remove the two T2 screws  at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver. Remove the two T2 screws  at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
    • Turn off your Huawei Mate 9 smartphone and remove the SIM card tray with a SIM card removal tool.
    • Remove the two T2 screws at the base of the phone next to the USB Type- C port with a T2 Torx Screwdriver.
  2. Using a suction cup, carefully start pulling the display assembly from the back cover. Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly. While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
    • Using a suction cup, carefully start pulling the display assembly from the back cover.
    • Insert a pick when pulling the display assembly off the back cover, while sliding the pick along the edge of the phone to loosen the display assembly.
    • While removing the display assembly, make sure to not completely remove the back cover. This is due to the power button and fingerprint sensor cables still being connected to the motherboard.
  3. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  4. To protect the internal cables and components, you will need to carefully disconnect  the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver. Remove the metal plate with tweezers.
    • To protect the internal cables and components, you will need to carefully disconnect the battery connector. Ensure the 1.3 mm Phillips #000 screws securing the metal plate is removed with a Phillips 000 screwdriver.
    • Remove the metal plate with tweezers.
    • Disconnect the battery connector from the motherboard using the spudger.
  5. Using a spudger, disconnect the battery connector. After disconnecting the battery connector, you can now completely remove the back cover.
    • Using a spudger, disconnect the battery connector.
    • After disconnecting the battery connector, you can now completely remove the back cover.
  6. Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate. Remove the metal plate with tweezers. After removing the metal plate, you can now remove and replace the rear camera from its slot.
    • Use a Philips 000 screwdriver to remove the two 1.0 mm Philips #1 screws securing the metal plate.
    • After removing the metal plate, you can now remove and replace the rear camera from its slot.
  7. To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly. Disconnect the front camera connector and remove the front-facing camera.
    • To remove the front-facing camera, peel off the conducting fabric from the metal shield on the display assembly.
    • Disconnect the front camera connector and remove the front-facing camera.
Conclusión
Rogelio Ramirez
Miembro Desde 25/06/17
452 Reputación
3 Guías creadas
Equipo
UC Davis, Team S7-G8, Lore Fall 2018 Miembro de UC Davis, Team S7-G8, Lore Fall 2018
UCD-LORE-F18S7G8
3 Miembros
3 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 35
Todo El Tiempo: 939
