Saltar al contenido principal
Huawei Mate 10 lite USB Port replacement
Qué necesitas
  1. Huawei Mate 10 lite USB Port replacement, Remove SIM card: paso 1, imagen 1 de 1
    • Remove the SIM card by inserting a paper clip or a special tool into the hole on the SIM card tray until it comes out.
  2. Huawei Mate 10 lite USB Port replacement, Open the housing: paso 2, imagen 1 de 2 Huawei Mate 10 lite USB Port replacement, Open the housing: paso 2, imagen 2 de 2
    • Remove the Torx T2 screws at the bottom of the case (next to the USB port)
    • Insert the opening tool on the lower end and in between the housing
    • Run the opening tool along the sides to open it
    • Lay the device face down and lift the back cover to the left
  3. Huawei Mate 10 lite USB Port replacement, Remove the cables and screws: paso 3, imagen 1 de 2 Huawei Mate 10 lite USB Port replacement, Remove the cables and screws: paso 3, imagen 2 de 2
    • Red: Phillips #00 screws
    • Blue: Use the spudger to remove the covers
    • Use a spudger to remove the cable going to the back panel and those going over the battery
    • Yellow: Detach the antenna cable from the USB board
  4. Huawei Mate 10 lite USB Port replacement, Detach the USB board: paso 4, imagen 1 de 1
    • lift the speaker out by lifting it from the right or left. Warning: this may require some force as the speaker is glued.
    • Lift the USB board out .
    • If there are no silicone dust covers on the replacement part (like here on the aux port), then replace those from donor parts and place them on the new replacement part in the same orientation. This cover also serves to ensure that no light shines through the openings
Conclusión
Follow this guide in reversed order to reassemble your device.
Una persona más ha completado esta guía.
Un agradecimiento especial a estos traductores:
de en
100%
¡ oldturkey03 nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Maximilian Deisz
Miembro Desde 10/04/21
524 Reputación
2 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 42
Todo El Tiempo: 762
