Introducción
If you are experiencing issues with your phone's speaker, this guide will show you how to repair or replace it.
Partes
No se requieren partes.
  1. Depress the top of the battery cover, and pull downwards towards the base of the phone.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Remove the battery by levering the battery out, using the cut just below the camera.
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. ¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
    Visita Nuestra Tienda
  4. Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  5. Using the T5 Torx screwdriver, remove the six 6mm screws. Using the T5 Torx screwdriver, remove the six 6mm screws.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  6. Using the opening tool, pry the back panel from the front panel. Work your way around the phone until the panels separate evenly.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  7. Pull out the speaker with a tweezers or your hands. Pull out the speaker with a tweezers or your hands.
    • Pull out the speaker with a tweezers or your hands.
Conclusión
Sebastian Solis
Miembro Desde 21/02/18
85 Reputación
1 Guía escrita
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 48
