Introducción
This guide will lead you throughout the process of the replacement of the charging port in Huawei M750
Qué necesitas
Depress the top of the battery cover, and pull downwards towards the base of the phone.
Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
Work the opening tool around the border of the camera and speaker cover, until it comes loose.
Using the opening tool, start prying out the motherboard from the front panel along the border.
When the motherboard seems separated from the front panel, pull it outwards.
The charging port is soldered to the motherboard, use this guide to do the replacement.
Una persona más ha completado esta guía.
