Saltar al contenido principal
Introducción
This guide will show how to replace the camera on a Huawei M750 smartphone.
  1. Depress the top of the battery cover, and pull downwards towards the base of the phone.
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Remove the battery by levering the battery out, using the cut just below the camera.
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  5. Using the T5 Torx screwdriver, remove the six 6mm screws. Using the T5 Torx screwdriver, remove the six 6mm screws.
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  6. Using the opening tool, pry the back panel from the front panel. Work your way around the phone until the panels separate evenly.
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
  7. The camera's connection to the motherboard is shown here.
    • The camera's connection to the motherboard is shown here.
    • Using the tweezers, disconnect the port, shown here in the picture.
  8. Using the tweezers, carefully remove the lens and lens casing.
    • Using the tweezers, carefully remove the lens and lens casing.
    • It should be held in by a simple tight fit. The front panel is what keeps the lens secured.
    • Do not touch the camera lens, or the digital camera component, if possible. This will prevent scratching, or damage.
Conclusión
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 2
Todo El Tiempo: 74
