Saltar al contenido principal
Huawei M750 Back Panel Replacement
Qué necesitas
  1. Huawei M750 Back Panel Replacement, Battery: paso 1, imagen 1 de 1
    • Depress the top of the battery cover, and pull downwards towards the base of the phone.
  2. Huawei M750 Back Panel Replacement: paso 2, imagen 1 de 1
    • Remove the battery by levering the battery out, using the cut just below the camera.
  3. Huawei M750 Back Panel Replacement, Back Panel: paso 3, imagen 1 de 1
    • Use the opening tool to start prying the camera and speaker cover, starting from the battery side.
    • Work the opening tool around the border of the camera and speaker cover, until it comes loose.
  4. Huawei M750 Back Panel Replacement: paso 4, imagen 1 de 2 Huawei M750 Back Panel Replacement: paso 4, imagen 2 de 2
    • Using the T5 Torx screwdriver, remove the six 6mm screws.
  5. Huawei M750 Back Panel Replacement: paso 5, imagen 1 de 2 Huawei M750 Back Panel Replacement: paso 5, imagen 2 de 2
    • Using the opening tool, pry the back panel from the front panel.
    • Work your way around the phone until the panels separate evenly.
    • This step may require a substantial amount of leverage.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 224
