Saltar al contenido principal
Huawei Ideos S7 Slim Mini-USB port Replacement
Qué necesitas
  1. Huawei Ideos S7 Slim Mini-USB port Replacement, Battery: paso 1, imagen 1 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement, Battery: paso 1, imagen 2 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement, Battery: paso 1, imagen 3 de 3
    • Place the tablet on a flat clear surface to keep the screen safe.
    • Slide the larger portion of the back cover off the tablet.
    • This will reveal the battery.
  2. Huawei Ideos S7 Slim Mini-USB port Replacement: paso 2, imagen 1 de 2 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 2, imagen 2 de 2
    • Lift the battery out with your finger.
    • Make sure you use the slot near the bottom of the device as shown. Trying to lift from anywhere else will not work and may damage the battery or the device.
  3. Huawei Ideos S7 Slim Mini-USB port Replacement, Logic Board: paso 3, imagen 1 de 2 Huawei Ideos S7 Slim Mini-USB port Replacement, Logic Board: paso 3, imagen 2 de 2
    • Using a plastic opening tool, pry off the top cover casing gently by moving the tool along all three sides.
  4. Huawei Ideos S7 Slim Mini-USB port Replacement: paso 4, imagen 1 de 1
    • With a T5 hexagonal head, remove the nine black 2.5 mm torx screws. Place them carefully aside on the magnetic mat.
  5. Huawei Ideos S7 Slim Mini-USB port Replacement: paso 5, imagen 1 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 5, imagen 2 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 5, imagen 3 de 3
    • Using a plastic opening tool, pry off the back casing gently on each side of the tablet.
  6. Huawei Ideos S7 Slim Mini-USB port Replacement: paso 6, imagen 1 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 6, imagen 2 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 6, imagen 3 de 3
    • Using a Phillips #00 screwdriver, remove the following screws:
    • Four 5mm wide grey Phillips screws on the logic board.
    • One of the 5mm screws is hidden under the circular white tape in the center of the logic board.
    • Seven 3mm small grey Phillips screws (four on one side, three on the other) from the black side casing.
  7. Huawei Ideos S7 Slim Mini-USB port Replacement: paso 7, imagen 1 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 7, imagen 2 de 3 Huawei Ideos S7 Slim Mini-USB port Replacement: paso 7, imagen 3 de 3
    • Disconnect the five cables connected to the logic board and then carefully lift the logic board out of the casing.
  8. Huawei Ideos S7 Slim Mini-USB port Replacement, Mini-USB port: paso 8, imagen 1 de 2 Huawei Ideos S7 Slim Mini-USB port Replacement, Mini-USB port: paso 8, imagen 2 de 2
    Herramienta utilizada en este paso:
    Desoldering Pump
    $3.99
    Comprar
    • During soldering, perform this task in a well ventilated area and wear safety glasses to protect your eyes .
    • Heat the solder to the mini-USB port.
    • Remove the melted solder using a solder sucker or desoldering braid.
    • Replace the old mini-USB port with a new one by attaching it using a new solder.
    • Let cool, then replace logic board in tablet.
Conclusión
Una persona más ha completado esta guía.
Equipo
UC Davis, Team 1-1, Oliver Fall 2016 Miembro de UC Davis, Team 1-1, Oliver Fall 2016
UCD-OLIVER-F16S1G1
5 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 427
