Saltar al contenido principal
Huawei Honor 6x Rear Camera Replacement
Qué necesitas
  1. Huawei Honor 6x Rear Camera Replacement, SIM Card: paso 1, imagen 1 de 1
    • Turn off the device.
  2. Huawei Honor 6x Rear Camera Replacement: paso 2, imagen 1 de 2 Huawei Honor 6x Rear Camera Replacement: paso 2, imagen 2 de 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Rear Camera Replacement: paso 3, imagen 1 de 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Rear Camera Replacement: paso 4, imagen 1 de 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Rear Camera Replacement, Back Cover: paso 5, imagen 1 de 2 Huawei Honor 6x Rear Camera Replacement, Back Cover: paso 5, imagen 2 de 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Rear Camera Replacement: paso 6, imagen 1 de 3 Huawei Honor 6x Rear Camera Replacement: paso 6, imagen 2 de 3 Huawei Honor 6x Rear Camera Replacement: paso 6, imagen 3 de 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Rear Camera Replacement: paso 7, imagen 1 de 2 Huawei Honor 6x Rear Camera Replacement: paso 7, imagen 2 de 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Rear Camera Replacement: paso 8, imagen 1 de 3 Huawei Honor 6x Rear Camera Replacement: paso 8, imagen 2 de 3 Huawei Honor 6x Rear Camera Replacement: paso 8, imagen 3 de 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Rear Camera Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Rear Camera Replacement, Rear Camera: paso 10, imagen 1 de 3 Huawei Honor 6x Rear Camera Replacement, Rear Camera: paso 10, imagen 2 de 3 Huawei Honor 6x Rear Camera Replacement, Rear Camera: paso 10, imagen 3 de 3
    • Pry the two connectors off by wedging a spudger, or your finger, underneath the connector.
  11. Huawei Honor 6x Rear Camera Replacement: paso 11, imagen 1 de 1
    • Gently remove the camera assembly using a spudger or two fingers.
Conclusión
2 personas más completaron esta guía.
M Morgan
Miembro Desde 10/08/18
686 Reputación
1 Guía escrita
Equipo
Cal Poly, Team S13-G5, White Fall 2018 Miembro de Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 11
Ultimos 30 días: 32
Todo El Tiempo: 1,101
