Saltar al contenido principal
Huawei Honor 6x Fingerprint Scanner Replacement
Qué necesitas
  1. Huawei Honor 6x Fingerprint Scanner Replacement, SIM Card: paso 1, imagen 1 de 1
    • Turn off the device.
  2. Huawei Honor 6x Fingerprint Scanner Replacement: paso 2, imagen 1 de 2 Huawei Honor 6x Fingerprint Scanner Replacement: paso 2, imagen 2 de 2
    • Insert the SIM Card Eject Tool into the SIM card tray hole.
    • Press the eject tool into the hole until the tray clicks open.
  3. Huawei Honor 6x Fingerprint Scanner Replacement: paso 3, imagen 1 de 1
    • Remove the SIM tray from the device using two fingers.
    • When reinserting the SIM card, be sure it is properly aligned with the SIM tray.
  4. Huawei Honor 6x Fingerprint Scanner Replacement: paso 4, imagen 1 de 1
    • Remove the SIM card from the compartment using two fingers.
  5. Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: paso 5, imagen 1 de 2 Huawei Honor 6x Fingerprint Scanner Replacement, Back Cover: paso 5, imagen 2 de 2
    • Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
    • Pry the screen off the back of the phone by pushing down on the opening tool.
  6. Huawei Honor 6x Fingerprint Scanner Replacement: paso 6, imagen 1 de 3 Huawei Honor 6x Fingerprint Scanner Replacement: paso 6, imagen 2 de 3 Huawei Honor 6x Fingerprint Scanner Replacement: paso 6, imagen 3 de 3
    • Slide the opening tool or spudger along the bottom of the phone and around the edge.
  7. Huawei Honor 6x Fingerprint Scanner Replacement: paso 7, imagen 1 de 2 Huawei Honor 6x Fingerprint Scanner Replacement: paso 7, imagen 2 de 2
    • Once three sides of the screen are detached, pry the phone apart using two hands.
    • When separating the back panel from the screen, do not pull them too far apart. There is an interconnect that is attached to both sides that could break, or tear, if pulled too far.
  8. Huawei Honor 6x Fingerprint Scanner Replacement: paso 8, imagen 1 de 3 Huawei Honor 6x Fingerprint Scanner Replacement: paso 8, imagen 2 de 3 Huawei Honor 6x Fingerprint Scanner Replacement: paso 8, imagen 3 de 3
    • Remove the five 4mm Phillips #00 screws using a screwdriver.
  9. Huawei Honor 6x Fingerprint Scanner Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard cover from the device using a spudger or your fingers.
  10. Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: paso 10, imagen 1 de 2 Huawei Honor 6x Fingerprint Scanner Replacement, Fingerprint Scanner: paso 10, imagen 2 de 2
    • Disconnect the fingerprint scanner cable attached to the motherboard using a spudger or your finger.
  11. Huawei Honor 6x Fingerprint Scanner Replacement: paso 11, imagen 1 de 1
    • Apply heat around the finger print scanner assembly using a heat gun or hair dryer.
  12. Huawei Honor 6x Fingerprint Scanner Replacement: paso 12, imagen 1 de 1
    • Separate the fingerprint scanner assembly from the back panel using a spudger.
    • This step can be difficult. You may consider using a metal spudger.
    • Be careful not to damage the black rubber adhesive around the fingerprint scanner. It is needed for water and dust resistance.
  13. Huawei Honor 6x Fingerprint Scanner Replacement: paso 13, imagen 1 de 1
    • Remove the finger print scanner from the device by lifting it with two fingers.
    • When reattaching the fingerprint scanner assembly, additional adhesive may be required.
Conclusión
5 personas más completaron esta guía.
Tessa Kemper
Miembro Desde 10/08/18
591 Reputación
3 Guías creadas
Equipo
Cal Poly, Team S13-G5, White Fall 2018 Miembro de Cal Poly, Team S13-G5, White Fall 2018
CPSU-WHITE-F18S13G5
Miembros de 4
14 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 51
Todo El Tiempo: 1,416
