Saltar al contenido principal
Huawei Ascend Y300 Rear Facing Camera Replacement
Qué necesitas
  1. Huawei Ascend Y300 Rear Facing Camera Replacement, Rear Facing Camera: paso 1, imagen 1 de 1
    • Place the phone screen down on a flat surface. Underneath the camera there will be a indentation, place your thumb or pointer finger on the indentation and pull gently up towards you. The back of the phone should pop off easily.
  2. Huawei Ascend Y300 Rear Facing Camera Replacement: paso 2, imagen 1 de 2 Huawei Ascend Y300 Rear Facing Camera Replacement: paso 2, imagen 2 de 2
    • Underneath the back of the phone you will find the battery. The battery is located in the middle of the phone's inner backing. By the battery you will find a similar indentation; place your thumb in the indentation and lift the battery towards you. The battery will come right out.
  3. Huawei Ascend Y300 Rear Facing Camera Replacement: paso 3, imagen 1 de 3 Huawei Ascend Y300 Rear Facing Camera Replacement: paso 3, imagen 2 de 3 Huawei Ascend Y300 Rear Facing Camera Replacement: paso 3, imagen 3 de 3
    • Along the edges of the phone you will find 8 screws, to remove these screws use a screwdriver( T5 if you are using the screwdriver found in the ifixit 54 bit driver kit)
    • Take the screws out by twisting left and set them in a spot where you will not lose them.
  4. Huawei Ascend Y300 Rear Facing Camera Replacement: paso 4, imagen 1 de 2 Huawei Ascend Y300 Rear Facing Camera Replacement: paso 4, imagen 2 de 2
    • Use the blue plastic opening tool by sliding it along the edges of the phone to pull back the frame.
  5. Huawei Ascend Y300 Rear Facing Camera Replacement: paso 5, imagen 1 de 2 Huawei Ascend Y300 Rear Facing Camera Replacement: paso 5, imagen 2 de 2
    • After removing the phone's frame, you will see the camera placed in a metallic cube, to remove the cube lift the edge gently and pull to the left.
    • You will notice the cube is attached to a copper ribbon, do not separate the cube from the ribbon!! it is attached.
  6. Huawei Ascend Y300 Rear Facing Camera Replacement: paso 6, imagen 1 de 1
    • CONGRATULATIONS!!! you have successfully completed this guide, please share this guide with your friends
    • Yay! Party time don't forget the bean dip
Conclusión
Julie Vasquez
Miembro Desde 11/30/17
133 Reputación
1 Guía escrita
Un comentario
Very specific and thorough. Wonderful job ladies!
Dan Hartzell - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 457
