Saltar al contenido principal
Huawei Ascend W1 Rear Camera Lens Replacement
Qué necesitas
  1. Huawei Ascend W1 Rear Camera Lens Replacement, The phone's orientation.: paso 1, imagen 1 de 1
    • Flip the device over so that the back of the phone is facing you and the screen is against your palm.
  2. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the back cover.: paso 2, imagen 1 de 1
    • Locate the slit at the bottom of the back cover.
    • Using your fingernail, lift up on the back cover to expose the battery.
  3. Huawei Ascend W1 Rear Camera Lens Replacement: paso 3, imagen 1 de 1
    • Lift the back cover off the phone.
    • The back cover is snapped onto the phone so you will feel it unsnapping as you remove it.
  4. Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: paso 4, imagen 1 de 3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: paso 4, imagen 2 de 3 Huawei Ascend W1 Rear Camera Lens Replacement, Removing the battery.: paso 4, imagen 3 de 3
    • Find the indented notch at the base of the battery.
    • Lift the battery out of the phone with your fingers by pressing forward and lifting upward.
  5. Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: paso 5, imagen 1 de 2 Huawei Ascend W1 Rear Camera Lens Replacement, Rear Camera Lens: paso 5, imagen 2 de 2
    • After removing the battery, remove the 2mm screws using a T5 Torx screwdriver.
    • There are eleven screws that hold the middle cover to the rest of the phone.
  6. Huawei Ascend W1 Rear Camera Lens Replacement: paso 6, imagen 1 de 2 Huawei Ascend W1 Rear Camera Lens Replacement: paso 6, imagen 2 de 2
    • Use tweezers to gently press against the back of the lens from the back of the frame.
    • Use tweezers to pry off the lens from the front of the frame.
Conclusión
Tanner Cline
Miembro Desde 11/01/18
169 Reputación
2 Guías creadas
Equipo
IUPUI, Team S3-G2, Harley Fall 2018 Miembro de IUPUI, Team S3-G2, Harley Fall 2018
IUPUI-HARLEY-F18S3G2
3 Miembros
4 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 121
