Introducción
Replace your phone's damaged front or rear camera to improve your photographs. Replacing the front and rear cameras follow the same series of steps.
Qué necesitas
Pull and twist the pin near the bottom left-side of the phone to remove it from the headphone jack.
Firmly push down on the black plastic covering at the bottom of the phone, and pull down.
Remove the following screws securing the logic board to the main frame:
Five 2mm Phillips #000 screws
Two 2.5mm Phillips #000 screws
Use the flat end of a spudger to gently snap open the first clip located on the the right arm of the retaining plate.
Use the flat end of a spudger to gently snap the second clip located on the left arm of the retaining plate.
Use the flat end of a spudger to gently lift the upper retaining plate from the phone.
Remove the two 2mm Phillips #000 screws securing the copper flex cable to the silver metal tab.
Use the pointy end of a spudger to wedge underneath the black circular vibrator motor near the bottom right of the phone.
Slowly lift up to separate the black circular vibrator motor from the adhesive.
Flip over the motherboard to access the camera connector sockets.
Use the pointy end of a spudger to gently pop up off the rear camera from the bottom right corner.
Use the pointy end of a spudger to gently pop up off the front camera from the bottom right corner.
3 personas más completaron esta guía.
