Saltar al contenido principal
Introducción
Replacing the 8GB of ram in my HP zBook studio g3 mobile workstation to 16 GB
  1. Remove the 4 screws holding down the dust filter
    • Remove the 4 screws holding down the dust filter
    • Remove the dust filter
  2. Remove the 4 outer screws.
    • Remove the 4 outer screws.
    • Remove the 2 inner screws holding the housing down.
    • Now lift the housing. This may require some force
  3. Remove the old ram module by pushing these two tabs outwards. The module should swing up Now pull the module out away from the holder
    • Remove the old ram module by pushing these two tabs outwards. The module should swing up
    • Now pull the module out away from the holder
    • Note: The removal of the module should not require a lot of force
  4. Orient the memory modules such that then notch in the connector lines up with the grove in the module
    • Orient the memory modules such that then notch in the connector lines up with the grove in the module
    • slide the module all the way into the holder such that the pins are in the connector
    • Push down on the module to lock it in the holders
    • Note: Make sure the module is in straight
Conclusión
3 personas más completaron esta guía.
jort
Miembro Desde 28/02/15
166 Reputación
1 Guía escrita
3 comentarios
Would be really good to have one for the SSD
Andrew Hansford - Contestar
I am thinking of expanding the storage on this model. If I get around to it I’ll post a guide
jort -
For retail stores like me this is very helpful. I can send to customers so they can upgrade themselves. Thanks for sharing
My Website: Laptop Workstation cũ Tphcm
Laptop Titan - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 19
Todo El Tiempo: 3,508
