Saltar al contenido principal
Hp Pavilion dv6-2155dx Optical Drive Replacement
Qué necesitas
  1. Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: paso 1, imagen 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement, Optical Drive: paso 1, imagen 2 de 2
    • Flip the computer around to the back side.
    • Remove the three screws from the memory module cover.
    • Screws will not come out all the way.
    • All screws to loosen/removed in this guide will require a Phillips #01 screwdriver.
  2. Hp Pavilion dv6-2155dx Optical  Drive Replacement: paso 2, imagen 1 de 1
    • Remove the screw completely from the memory module panel to help release the Optical drive from the body of the computer.
    • The screw is 7mm long and head is 4mm wide.
  3. Hp Pavilion dv6-2155dx Optical  Drive Replacement: paso 3, imagen 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: paso 3, imagen 2 de 2
    • Locate the small hole next to the eject button.
    • Get a paper clip and insert in to the small hole until you hear a clicking sound and seeing the tray pop out.
    • Before removing the optical drive, be sure that there is nothing in the drive. Optical drives are fragile so handle with care.
  4. Hp Pavilion dv6-2155dx Optical  Drive Replacement: paso 4, imagen 1 de 2 Hp Pavilion dv6-2155dx Optical  Drive Replacement: paso 4, imagen 2 de 2
    • Gently pull the Optical drive out of the slot until the whole thing comes out.
Conclusión
2 personas más completaron esta guía.
Joseph Sanda
Miembro Desde 03/10/16
522 Reputación
4 Guías creadas
Equipo
UMass Dartmouth, Team 2-2, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 2-2, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G2
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 22
Todo El Tiempo: 793
