Saltar al contenido principal
Hp 15-f305dx Hard Drive Replacement
Qué necesitas
  1. Hp 15-f305dx Hard Drive Replacement, Battery: paso 1, imagen 1 de 1
    • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
  2. Hp 15-f305dx Hard Drive Replacement: paso 2, imagen 1 de 1
    • Turn the computer upside down on a flat surface.
  3. Hp 15-f305dx Hard Drive Replacement: paso 3, imagen 1 de 3 Hp 15-f305dx Hard Drive Replacement: paso 3, imagen 2 de 3 Hp 15-f305dx Hard Drive Replacement: paso 3, imagen 3 de 3
    • Firmly slide the release latch to unlock the battery and slide the battery release latch to release the battery.
  4. Hp 15-f305dx Hard Drive Replacement: paso 4, imagen 1 de 2 Hp 15-f305dx Hard Drive Replacement: paso 4, imagen 2 de 2
    • Lift the battery from the middle and then pivot it outward to remove it from the computer.
  5. Hp 15-f305dx Hard Drive Replacement, Keyboard: paso 5, imagen 1 de 1
    • Flip the laptop around.
  6. Hp 15-f305dx Hard Drive Replacement: paso 6, imagen 1 de 2 Hp 15-f305dx Hard Drive Replacement: paso 6, imagen 2 de 2
    • Remove the single 7 mm screw from the top middle of the laptop using a Phillips #0 screwdriver.
  7. Hp 15-f305dx Hard Drive Replacement: paso 7, imagen 1 de 2 Hp 15-f305dx Hard Drive Replacement: paso 7, imagen 2 de 2
    • Pry the keyboard out of the laptop gently and flip the keyboard around.
  8. Hp 15-f305dx Hard Drive Replacement: paso 8, imagen 1 de 1
    • Disconnect the connected cable from the mainboard.
  9. Hp 15-f305dx Hard Drive Replacement, Hard Drive: paso 9, imagen 1 de 2 Hp 15-f305dx Hard Drive Replacement, Hard Drive: paso 9, imagen 2 de 2
    • Remove the twelve screws from the bottom of the laptop with the Philips #0 Screwdriver.
  10. Hp 15-f305dx Hard Drive Replacement: paso 10, imagen 1 de 3 Hp 15-f305dx Hard Drive Replacement: paso 10, imagen 2 de 3 Hp 15-f305dx Hard Drive Replacement: paso 10, imagen 3 de 3
    • Eject the CD player on the side of the laptop by sliding it out.
  11. Hp 15-f305dx Hard Drive Replacement: paso 11, imagen 1 de 3 Hp 15-f305dx Hard Drive Replacement: paso 11, imagen 2 de 3 Hp 15-f305dx Hard Drive Replacement: paso 11, imagen 3 de 3
    • Use a Phillips # 1 Screwdriver to unscrew the three screws under the CD player
  12. Hp 15-f305dx Hard Drive Replacement: paso 12, imagen 1 de 3 Hp 15-f305dx Hard Drive Replacement: paso 12, imagen 2 de 3 Hp 15-f305dx Hard Drive Replacement: paso 12, imagen 3 de 3
    • Flip the device around and open it. Use the blue spudger tool to remove the casing around the keyboard space by driving it the crease and propping it up.
    • Once you have used the spudger tool all the way around the casing, lift the casing up from the device.
  13. Hp 15-f305dx Hard Drive Replacement: paso 13, imagen 1 de 2 Hp 15-f305dx Hard Drive Replacement: paso 13, imagen 2 de 2
    • Use a Phillips #0 screwdriver to remove the screw that holds the USB drive in the bottom right corner near the hard drive. Once removed, lift the USB drive off of the hard drive.
  14. Hp 15-f305dx Hard Drive Replacement: paso 14, imagen 1 de 3 Hp 15-f305dx Hard Drive Replacement: paso 14, imagen 2 de 3 Hp 15-f305dx Hard Drive Replacement: paso 14, imagen 3 de 3
    • Lift the hard drive from the device and unconnect the cord attached to it.
Conclusión
2 personas más completaron esta guía.
Brandon
Miembro Desde 03/23/18
681 Reputación
4 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 25
Todo El Tiempo: 4,266
