Saltar al contenido principal
How to Tighten GEN 2 Wheelchair Wheels
Qué necesitas
  1. How to Tighten GEN 2 Wheelchair Wheels, How to Tighten GEN 2 Wheelchair Wheels: paso 1, imagen 1 de 1
    • Inspect the chair to see which wheel is loose.
    • Tighten the outer bolt with a 19 mm socket wrench.
  2. How to Tighten GEN 2 Wheelchair Wheels: paso 2, imagen 1 de 1
    • Tighten the nut facing the inside of the chair with a 19 mm wrench.
Conclusión
If wheel does not feel properly secured, keep tightening the wheel in small amounts until the wheel is secure.
Equipo
Cal Poly, Team 14-8, Maness Spring 2013 Miembro de Cal Poly, Team 14-8, Maness Spring 2013
CPSU-MANESS-S13S14G8
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 1,893
