Saltar al contenido principal
How to solder a severed ECU return to battery terminal cable
Qué necesitas
  1. How to solder a severed ECU return to battery terminal cable, How to solder a severed ECU return to battery terminal cable: paso 1, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable, How to solder a severed ECU return to battery terminal cable: paso 1, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable, How to solder a severed ECU return to battery terminal cable: paso 1, imagen 3 de 3
    • Be sure to turn your car completely off before touching any component of the battery.
    • Disconnect the ECU and positive cable by using your 12mm wrench to loosen the bolt on the battery's positive terminal.
    • Once the cables are disconnected, place the positive cable out of the way.
  2. How to solder a severed ECU return to battery terminal cable: paso 2, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable: paso 2, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable: paso 2, imagen 3 de 3
    • Place a piece of cardboard on top of the battery to work on.
    • Peel the black electrical tape off of the ECU wire.
    • If that doesn't work, carefully take a knife and cut the tape off
  3. How to solder a severed ECU return to battery terminal cable: paso 3, imagen 1 de 2 How to solder a severed ECU return to battery terminal cable: paso 3, imagen 2 de 2
    • Spread the individual wires apart in each cable.
    • Then mesh the ends of the cables together.
    • Pinch down on the meshed cable ends.
    • They should hold themselves together.
    • If the cables are dirty, use the wire brush to clean off any debris.
  4. How to solder a severed ECU return to battery terminal cable: paso 4, imagen 1 de 2 How to solder a severed ECU return to battery terminal cable: paso 4, imagen 2 de 2
    • Plug your soldering iron in to let it warm up.
    • The one I am using takes about 15 minutes to warm up.
    • Tape the white cable to the cardboard so that the cables don't move around while you're working.
  5. How to solder a severed ECU return to battery terminal cable: paso 5, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable: paso 5, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable: paso 5, imagen 3 de 3
    • Gingerly apply solder to the severed cables.
    • For help with soldering best practices, check out our How to Solder and Desolder Connections guide.
    • When done the cables should have no issue supporting their own weight, and should be able to withstand a little tug.
    • If you see smoke, just back off and slow down.
  6. How to solder a severed ECU return to battery terminal cable: paso 6, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable: paso 6, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable: paso 6, imagen 3 de 3
    • Take your shrink wrap, and wrap it around the cable.
    • Use a hair dryer to blast the shrink wrap with heat. Move the dryer up and down over the wrap.
    • Do this for about a minute or until the wrap has formed around the wire.
  7. How to solder a severed ECU return to battery terminal cable: paso 7, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable: paso 7, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable: paso 7, imagen 3 de 3
    • Wrap a few layers of electrical tape over the heat shrink tubing.
    • Work your way up the cable and cut the tape once you've reached the top.
    • Once more tape the cable starting a few inches below the solder and work your way back to the top. Cut the tape again.
  8. How to solder a severed ECU return to battery terminal cable: paso 8, imagen 1 de 3 How to solder a severed ECU return to battery terminal cable: paso 8, imagen 2 de 3 How to solder a severed ECU return to battery terminal cable: paso 8, imagen 3 de 3
    • Place the positive cable down first.
    • Then place a washer between the cables.
    • Place the ECU cable, then one final washer, and finally tighten the bolt on top.
    • Place the positive cable on the battery first. (The one we weren't fixing)
Conclusión
To reassemble your device, besure to place the positive cable down first. Then place a washer between the cables. Place the last washer on top of the ECU cable, then bolt down.
Kevin Fitzgerald
Miembro Desde 04/29/20
157 Reputación
1 Guía escrita
Equipo
UW Tacoma, Team S1-G6, Cardinal Spring 2020 Miembro de UW Tacoma, Team S1-G6, Cardinal Spring 2020
UWT-CARDINAL-S20S1G6
2 Miembros
2 Guías creadas
Un comentario
Hello ; I need help fixing my ECU it over heats and disconnects the data lines from the other computers in the car leading it to not start or start and fail and I cannot replace it without the data on the original ECU
If anyone knows a trick on how to copy the data from the ecu or fix the power issue please feel free to contact me at amd13@windowslive.com or via mobile+9665633330544
Regards
Ali Al Dawood
And thanks for the tips they were helpful I managed to shift gears but not start the car
Much appreciated
Ali - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 735
