Saltar al contenido principal
How to rewire a Nostalgia Electrics PCM805
Qué necesitas
  1. How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: paso 1, imagen 1 de 2 How to rewire a Nostalgia Electrics PCM805, Nostalgia Electrics PCM805 Wiring Teardown: paso 1, imagen 2 de 2
    • Locate the tie strap holding the wires and cut with a pair of scissors.
    • Use care not to snip the wires.
  2. How to rewire a Nostalgia Electrics PCM805: paso 2, imagen 1 de 3 How to rewire a Nostalgia Electrics PCM805: paso 2, imagen 2 de 3 How to rewire a Nostalgia Electrics PCM805: paso 2, imagen 3 de 3
    • Make note of the wiring arrangement of each bundle before this step.
    • Using wire cutters, cut each wire as close to the wire connector as possible.
    • Cut the wires in both bundles.
    • To reassemble the cotton candy maker after cutting the wires, follow our rewiring guide.
  3. How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: paso 3, imagen 1 de 2 How to rewire a Nostalgia Electrics PCM805, How to rewire a Nostalgia Electrics PCM805: paso 3, imagen 2 de 2
    • Using the wire stripper, remove 1/2 inch of the wire insulation at the end of each wire to expose the bare wire for re-connection.
  4. How to rewire a Nostalgia Electrics PCM805: paso 4, imagen 1 de 3 How to rewire a Nostalgia Electrics PCM805: paso 4, imagen 2 de 3 How to rewire a Nostalgia Electrics PCM805: paso 4, imagen 3 de 3
    • Twist the exposed ends of the wires so that they stay together.
    • Push the wire cap onto the exposed ends while holding the wires and twist in a clock-wise direction until it is tight.
    • Repeat this process for both bundles of wires.
    • Do not attempt to power on the device without the wire caps on or mix wires between the bundles.
Linea de Meta
Carlton
Miembro Desde 01/13/15
672 Reputación
5 Guías creadas
Equipo
USF Tampa, Team 3-5, Hickman Winter 2015 Miembro de USF Tampa, Team 3-5, Hickman Winter 2015
USFT-HICKMAN-W15S3G5
5 Miembros
8 Guías creadas
Un comentario
DO NOT TRY THIS..it broke my machine TO NOT TRY THIS
Izzy - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 5
Todo El Tiempo: 639
