Saltar al contenido principal
How to restore a shrunken sweater
Qué necesitas
  1. How to restore a shrunken sweater, How to restore a shrunken sweater: paso 1, imagen 1 de 1
    • Add 2/3 full of water into the washbasin.
    • Add 20 ml of Baby Shampoo into the washbasin.
    • The volume of water needed depends on the size of the sweater. The larger the sweater, the more water needed.
  2. How to restore a shrunken sweater: paso 2, imagen 1 de 1
    • Soak the sweater into the washbasin with soapy water for 15 mins.
  3. How to restore a shrunken sweater: paso 3, imagen 1 de 3 How to restore a shrunken sweater: paso 3, imagen 2 de 3 How to restore a shrunken sweater: paso 3, imagen 3 de 3
    • Take out the sweater from the washbasin with soapy water.
    • Remove the sweater to the bucket filled with fresh warm water.
    • Rinse the sweater thoroughly.
  4. How to restore a shrunken sweater: paso 4, imagen 1 de 1
    • Take out the sweater from the bucket.
    • Wring the clothes gently to get excessive water out.
  5. How to restore a shrunken sweater: paso 5, imagen 1 de 1
    • Place the sweater flat in the center of the bath towel.
  6. How to restore a shrunken sweater: paso 6, imagen 1 de 3 How to restore a shrunken sweater: paso 6, imagen 2 de 3 How to restore a shrunken sweater: paso 6, imagen 3 de 3
    • Roll while wringing the towel together with the sweater in order to dry the sweater.
    • Redo the process for a couple times until the sweater is dry to the touch.
    • Unfold the towel and take out the sweater
    • Spread out the sweater flat and let it dry.
Conclusión
Una persona más ha completado esta guía.
Zhou Zhou
Miembro Desde 10/26/18
148 Reputación
1 Guía escrita
Equipo
UC Davis, Team S2-G8, Bender Fall 2018 Miembro de UC Davis, Team S2-G8, Bender Fall 2018
UCD-BENDER-F18S2G8
3 Miembros
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 427
