Saltar al contenido principal
Cómo reemplazar el IC táctil en el botón de inicio
Qué necesitas
    • En este tutorial, aprenderás a reparar el botón de inicio en un iPhone 7. Para obtener más información sobre la reparación de iPhone y más, consulta mis otras guías.
Conclusión
Para volver a armar tu dispositivo, sigue estas instrucciones en orden inverso.
18 personas más completaron esta guía.
Un agradecimiento especial a estos traductores:
en es
100%
¡ Francisco Javier Saiz Esteban nos está ayudando a reparar el mundo! ¿Quieres contribuir?
Empezar a traducir ›
Alex Sander
Miembro Desde 02/28/17
38,219 Reputación
202 Guías creadas
11 comentarios
Do you have clear instructions and tools how to do it
Abbigail huari - Contestar
So do you need to move the chip to replace the home button?
Dylan McGarrity - Contestar
You need to reball or replace the chip to repair Touch ID.
Alex Sander -
If the home button or its flex cable is broken then it's completely shot, short of taking it to an Apple store for a replacement.
On the other hand, it could also be caused by the home button's extension flex cable running through the back of the lcd, and/or a damaged camera/speaker flex cable on top. So make sure to check all those out carefully before resorting to the Apple store.
After reading through a lot of suggestions, here's one which sounded interesting to me. Low and behold, this solution has actually worked!! I have removed that single screw completely, restarted the phone, and the home button started working perfectly.
05/31/2017 by screensaviors
I loosened the screw behind the center of the home button (holding it to the metal bracket), and it magically works now. This may not fix a lot of them, but it worked for me. I was just tightening that screw snug, but must have been too snug.
billa.4you - Contestar
Very good points, it will certainly help people to resolve some of their problems, thanks for sharing your experience!
Alex Sander -
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 43
Ultimos 30 días: 117
Todo El Tiempo: 35,664
