Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to replace the start capacitor in your food processor
Qué necesitas
      • Pull the mains plug to fully isolate the food processor from electricity.
      • Place the heavy machine on a stable work surface before opening the housing.
      Pregunta a FixBot
      Agregar Comentario
      • Remove the three security Torx screws that hold the base to the motor block.
      • Lift the housing straight up and off the motor assembly.
      • Support the motor as you separate the cover because the assembly is heavy.
      Pregunta a FixBot
      Agregar Comentario
      • Locate the cylindrical start capacitor next to the thermal overload protector.
      • Read the capacitance printed on its label; the example unit uses 35 µF.
      • Always replace the capacitor with one of identical capacitance and at least the same voltage rating.
      Pregunta a FixBot
      Agregar Comentario
      • Take a clear photo of the capacitor terminals to record each wire’s colour and position.
      Pregunta a FixBot
      Agregar Comentario
      • Cut the existing cable tie and pull the spade connectors off the old capacitor.
      • Lift the capacitor out of its bracket and set it aside for recycling.
      Pregunta a FixBot
      Agregar Comentario
      • Slide the new 35 µF capacitor into the original bracket with the terminals facing up.
      • Reconnect each wire to the same terminals using the photo as reference.
      • Secure the capacitor with a fresh cable tie, keeping the tie clear of nearby wires.
      • Trim the excess tail of the tie so it cannot interfere with moving parts.
      Pregunta a FixBot
      Agregar Comentario
      • Route all leads back into their original channels so nothing will be pinched by the cover.
      • Confirm the mains cable sits properly in its strain-relief groove.
      Pregunta a FixBot
      Agregar Comentario
      • Align the cover with the motor block and lower it into place without forcing.
      • Reinstall the three security Torx screws and tighten them evenly.
      Pregunta a FixBot
      Agregar Comentario
      • Plug the appliance in and run it briefly to verify the motor now starts quickly and smoothly.
      • If it still hums or stalls, disconnect power and re-check the wiring and capacitor rating.
      Pregunta a FixBot
      Agregar Comentario
Conclusión
With a correctly rated start capacitor installed, your food processor regains full starting torque and reliable operation. Dispose of the failed capacitor responsibly and enjoy many more years of service from your machine.
Una persona más ha completado esta guía.
Ula Gantar
Miembro Desde 01/08/25
16,609 Reputación
81 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 15
Ultimos 30 días: 29
Todo El Tiempo: 247
