Saltar al contenido principal
How to replace or tighten the inner screws of an FC fan
Qué necesitas
  1. How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: paso 1, imagen 1 de 3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: paso 1, imagen 2 de 3 How to replace or tighten the inner screws of an FC fan, How to replace or tighten the inner screws of an FC fan: paso 1, imagen 3 de 3
    • Ensure the device is powered off completely and disconnected from any external power source.
    • Unlatch the four hinges located around the edge of the fan cage by gently pulling them away from the fan cage.
  2. How to replace or tighten the inner screws of an FC fan: paso 2, imagen 1 de 2 How to replace or tighten the inner screws of an FC fan: paso 2, imagen 2 de 2
    • Locate, loosen and remove the screw that is found at the bottom of the cage using a Phillips #1 screwdriver.
  3. How to replace or tighten the inner screws of an FC fan: paso 3, imagen 1 de 1
    • Remove the front half of the cage from the fan by wiggling gently it until it disconnects from the rest of the fan.
  4. How to replace or tighten the inner screws of an FC fan: paso 4, imagen 1 de 3 How to replace or tighten the inner screws of an FC fan: paso 4, imagen 2 de 3 How to replace or tighten the inner screws of an FC fan: paso 4, imagen 3 de 3
    • Twist the now exposed central fan cap clockwise to remove it from the fan blades.
  5. How to replace or tighten the inner screws of an FC fan: paso 5, imagen 1 de 2 How to replace or tighten the inner screws of an FC fan: paso 5, imagen 2 de 2
    • Twist the fan blades clockwise to remove them from the central axel.
  6. How to replace or tighten the inner screws of an FC fan: paso 6, imagen 1 de 3 How to replace or tighten the inner screws of an FC fan: paso 6, imagen 2 de 3 How to replace or tighten the inner screws of an FC fan: paso 6, imagen 3 de 3
    • Remove or tighten the two inner screws as necessary, making sure the screws are tightened only until you are met with slight resistance when reassembling.
Conclusión
Una persona más ha completado esta guía.
Zain Andani
Miembro Desde 09/12/23
133 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 17
Todo El Tiempo: 112
