Saltar al contenido principal
How to Replace a Nequare Cordless Vacuum S182 Filter
  1. How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: paso 1, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter, Filter: paso 1, imagen 2 de 2
    • Locate the black button to release the white motor unit from the rest of the vacuum cleaner.
  2. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 2, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 2, imagen 2 de 2
    • Hold down the black button to remove the white motor unit above and gently pull the motor unit upwards.
  3. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 3, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 3, imagen 2 de 2
    • Press the release button at the side of the dust canister to dispose of the debris.
    • Be sure to hold the the canister over a garbage can to avoid a spill.
  4. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 4, imagen 1 de 3 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 4, imagen 2 de 3 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 4, imagen 3 de 3
    • After emptying the debris, hold down the black button, then twist and pull the canister out.
  5. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 5, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 5, imagen 2 de 2
    • Take the filter out and dispose of it.
  6. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 6, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 6, imagen 2 de 2
    • Remove the black part by gently pushing from inside of the canister.
  7. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 7, imagen 1 de 2 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 7, imagen 2 de 2
    • Clean both the canister and the black part either by rinsing it out or using a wash cloth.
  8. How to Replace a Nequare Cordless Vacuum S182 Filter: paso 8, imagen 1 de 3 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 8, imagen 2 de 3 How to Replace a Nequare Cordless Vacuum S182 Filter: paso 8, imagen 3 de 3
    • Put the black part back into the canister and put in the new filter.
Conclusión
Una persona más ha completado esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 13
Ultimos 30 días: 34
Todo El Tiempo: 1,241
