Saltar al contenido principal
How to repair the foot pedal (spring)
Qué necesitas
  1. How to repair the foot pedal (spring), Pedal Spring: paso 1, imagen 1 de 2 How to repair the foot pedal (spring), Pedal Spring: paso 1, imagen 2 de 2
    • Turn over the EC20.
    • Unscrew all 7 screws on the back.
  2. How to repair the foot pedal (spring): paso 2, imagen 1 de 3 How to repair the foot pedal (spring): paso 2, imagen 2 de 3 How to repair the foot pedal (spring): paso 2, imagen 3 de 3
    • Put the EC20 on its side and put your thumb on the edge.
    • Place your other thumb on the jack input.
    • Pull them apart and slightly open the case.
  3. How to repair the foot pedal (spring): paso 3, imagen 1 de 3 How to repair the foot pedal (spring): paso 3, imagen 2 de 3 How to repair the foot pedal (spring): paso 3, imagen 3 de 3
    • Turn the EC20 around and place your thumb on one of the knobs.
    • Place your other thumb on the bottom edge where part of the casing sticks out.
    • Pull them apart, you should now be able to open the casing completely.
  4. How to repair the foot pedal (spring): paso 4, imagen 1 de 3 How to repair the foot pedal (spring): paso 4, imagen 2 de 3 How to repair the foot pedal (spring): paso 4, imagen 3 de 3
    • Push the rod out by using the screwdriver as a lever.
    • Pull out the rod with the wrench on the other side.
  5. How to repair the foot pedal (spring): paso 5, imagen 1 de 3 How to repair the foot pedal (spring): paso 5, imagen 2 de 3 How to repair the foot pedal (spring): paso 5, imagen 3 de 3
    • Turn around the upper casing.
    • Grab the pedal and pull it out of the casing.
  6. How to repair the foot pedal (spring): paso 6, imagen 1 de 3 How to repair the foot pedal (spring): paso 6, imagen 2 de 3 How to repair the foot pedal (spring): paso 6, imagen 3 de 3
    • Push the spring back in position on the ring.
    • Put the pedal back in the casing.
  7. How to repair the foot pedal (spring): paso 7, imagen 1 de 1
    • Push the rod back in position.
Conclusión
Close the casing again and fasten the casing with the screws. You have now successfully replaced the spring!
2 personas más completaron esta guía.
Un comentario
1979 iron head sportster where does the foot pedal spring go
Betty Cox - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 16
Todo El Tiempo: 1,374
