Saltar al contenido principal
How to repair an iPhone that won't charge - Tristar Replacement
Qué necesitas
  1. How to repair an iPhone that won't charge - Tristar Replacement, Check for a new charger: paso 1, imagen 1 de 1
    • Your cable could be bad, try a new one, possibly MFI certified ! (Made For iPhone) Or try a known-good one.
    • Try a new charging brick, or a known-good one that delivers at least 5V-1A
  2. How to repair an iPhone that won't charge - Tristar Replacement, Checking the charging port: paso 2, imagen 1 de 1
    • Check your charging port, it could be really dirty or obstructed
    • If it looks dirty, you can take the risk to insert a thin tool and try to pry out the dirt. I am not responsible for the harm you could do to your phone !
  3. How to repair an iPhone that won't charge - Tristar Replacement, Try known-good internals: paso 3, imagen 1 de 1
    • Try a known-good battery. Replace it if your phone charges again.
    • Try a known-good Lightning charging port. Replace it if your phone charges again.
    • I know, this is a picture of an iPhone 7, check the video for the 6S on the next step.
    • The whole french version of the process, video does help if you are an english-speaker !
  4. How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: paso 5, imagen 1 de 2 How to repair an iPhone that won't charge - Tristar Replacement, Now some real challenge: paso 5, imagen 2 de 2
    • If you are still reading, bad news, you probably have a motheboard problem !
    • It's probably U4500, or Tristar that's causing it, it fails very frequently on iPhones. You'll have to replace it.
    • Video tutorial for Tristar replacement on iPhone 6S
Conclusión
12 personas más completaron esta guía.
Alexandre Isaac
Miembro Desde 04/07/13
2,863 Reputación
8 Guías creadas
Equipo
The Repair Academy Miembro de The Repair Academy
Business
1 Miembro
20 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 100
Todo El Tiempo: 10,943
