Saltar al contenido principal
How to remove the Samsung LA40R81BD 40in LCD TV rear cover
Qué necesitas
  1. How to remove the Samsung LA40R81BD 40in LCD TV rear cover, Rear Cover: paso 1, imagen 1 de 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
Conclusión
11 personas más completaron esta guía.
Richdave
Miembro Desde 04/09/10
32,081 Reputación
30 Guías creadas
Equipo
Master Techs Miembro de Master Techs
Community
322 Miembros
2,535 Guías creadas
3 comentarios
Got cover off but how to unplug the wires
cpeeledc - Contestar
What size screws holds on the rear panel?
D Mack Miller - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 24,127
