Introducción
If your Arbor Rally longboard has felt sluggish recently or you're not satisfied with it's performance, this guide will help you improve your ride.
Qué necesitas
Use the half inch wrench to remove the nut on each wheel. Then remove each wheel.
Be careful not to lose the washers that sit between the nut and wheel, they are small and hard to find after you lose them.
Place the wheel on the axle followed by washer and then the nut.
Tighten the nut with your fingers as much as you can first and then use the wrench to finish the job.
Do not tighten the nut too much or else the wheel will not be able to spin. You should be able to slightly shake the wheel up and down along the axle.
4 personas más completaron esta guía.
2 comentarios
It is usual practice to clean bearings with alcohol or a citrus cleaner; the latter is safer but more likely to leave residues. Since a citrus cleaning is water-based, you must quickly dry your bearings in order to prevent rust.
