Introducción
Most leaks in modern automotive tires are caused by a foreign object—usually a nail or screw—puncturing the tire through the tread. This type of leak can be repaired by removing the object and inserting a rubber plug into the hole left behind.
Qué necesitas
Window cleaner or soapy water sprayed on the tire is a quick method for identifying the location of a leak. Always check the valve stem in addition to the tire itself.
Once you've identified the leak, prepare the tire and plug before removing the foreign object causing the leak (usually a nail or screw)
Prepare your tire plug by feeding it through the eye of the insertion needle before pulling any objects from the tire that maybe causing leaks.
Make sure your tire is well inflated. Inflate it to the maximum listed on the tire sidewall.
Una persona más ha completado esta guía.
