Introducción
This guide outlines the first steps necessary for internal repairs, such as: wheel, main board, sensor, and motor replacements. By the end of this, you will know how to disassemble bObsweep's cover completely.
Qué necesitas
Flip Bob over and remove the 7 screws around which hold the cover together.
Remove the main brush. Unscrew the holder, and lift the brush out. Reminder: Keep this screw separate from the others so you can use it later to reinstall.
Remove three circuit plugs from the motherboard. Pinch the small white tab on the side of each circuit plug and pull straight up to release each from the motherboard.
1. On the bottom left corner: a small connector with red, black and white wires.
2. One thick white wire that attaches on the right side of the previous connector.
3. On the top edge of bOb’s motherboard: a wide multicoloured connector.
Place the cover aside and begin your repair.
To reassemble your bObsweep, follow these instructions in reverse order.
Una persona más ha completado esta guía.
Un comentario
Change battery, and still does what it did before. Battery life is one bar only, and the moment u push start it shuts right off. Even after charging all day. Please help
