Saltar al contenido principal
How to install shower filter for your shower head
Qué necesitas
  1. How to install shower filter for your shower head, How to install shower filter for your shower head: paso 1, imagen 1 de 1
    • Ensure your water valve is in the closed position.
    • Begin by unscrewing the shower head from its original water outlet.
    • Reminder: You might need to cut off the tape that was previously used for reinforcement. This step might require the use of a wrench for disassembly, so it's recommended to have one on hand in advance.
  2. How to install shower filter for your shower head: paso 2, imagen 1 de 3 How to install shower filter for your shower head: paso 2, imagen 2 de 3 How to install shower filter for your shower head: paso 2, imagen 3 de 3
    • Take out the shower filter and rinse it under a faucet (either in the bathroom or any other location) for about 30 seconds to wet the internal filter layer.
    • This step also helps prevent the shower head outlet from getting blocked by the substances in the filter layer after installation.
  3. How to install shower filter for your shower head: paso 3, imagen 1 de 2 How to install shower filter for your shower head: paso 3, imagen 2 de 2
    • Install the shower filter onto the water outlet by turning it clockwise.
  4. How to install shower filter for your shower head: paso 4, imagen 1 de 1
    • Turn on the water after installation to check for leaks.
    • Attention: If there is a leak, wrapping a few rounds of waterproof tape around the joint can effectively prevent it.
    • Tools: waterproof tape
  5. How to install shower filter for your shower head: paso 5, imagen 1 de 2 How to install shower filter for your shower head: paso 5, imagen 2 de 2
    • Connect the shower head to the shower filter for installation (it's best to use a wrench).
    • After securing it, check again for any water leaks. If there is a leak, use waterproof tape as before.
Conclusión
Please check for leaks after the installation is complete.
To reassemble your device, please follow these instructions in reverse order.
Una persona más ha completado esta guía.
WenJia Zhao
Miembro Desde 09/05/23
181 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 123
