Saltar al contenido principal
How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears
Qué necesitas
  1. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: paso 1, imagen 1 de 1
    • Turn the device over so that the base is on top.
  2. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 2, imagen 1 de 1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 3, imagen 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 3, imagen 2 de 2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: paso 4, imagen 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, Motor: paso 4, imagen 2 de 2
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  5. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 5, imagen 1 de 2 How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 5, imagen 2 de 2
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
  6. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears, How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 6, imagen 1 de 1
    • Unscrew the two 10 mm philips head screws.
    • Unscrew the center 14 mm philips head screw.
    • Remove the plastic piece stabilizing the gear.
  7. How to grease the Lite FX Rotating Big Ball of Lite Model 1929 gears: paso 7, imagen 1 de 1
    • Apply oil to the gear directly from the oil bottle or with a Q-tip.
Conclusión
Equipo
Cal Poly, Team 17-3, Forte Winter 2014 Miembro de Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 1,102
