Saltar al contenido principal
How to flash Lenovo IdeaTab A1000L
Qué necesitas
  1. How to flash Lenovo IdeaTab A1000L, Welcome: paso 1, imagen 1 de 2 How to flash Lenovo IdeaTab A1000L, Welcome: paso 1, imagen 2 de 2
    • Requirements:
    • A internet conection
    • A charged A1000
    • A usb data cable
    • And most importantly a windows pc
    • Warning: don't do this if your tablet is already working or you modified the boot loader ,you can brick your tablet .
  2. How to flash Lenovo IdeaTab A1000L, Finding Firmware.: paso 2, imagen 1 de 2 How to flash Lenovo IdeaTab A1000L, Finding Firmware.: paso 2, imagen 2 de 2
  3. How to flash Lenovo IdeaTab A1000L, Unpacking the firmware: paso 3, imagen 1 de 1
    • Unzip the firmware and the flashtool in any folder only with latin characters.
  4. How to flash Lenovo IdeaTab A1000L, Flashing the firmware: paso 4, imagen 1 de 1
    • YOU CAN BRICK YOUR TABLET ON THIS STEP! I am not responsible for any bricking of a tablet.
    • open Flash_tool.exe. and select File > Open Scatter-loading file ... and select the file MT6577_Android_scatter_emmc.txt from the firmware folder
    • Check the box DA DL All With Check Sum and Press the Firmware -> Upgrade button
    • If this <-- happens check the firmware and delete checksum.ini from the firmware and try again
    • Plug in your tablet turned off
    • First wait if you get a green circle after flashing you have a successfully flashed tablet.
Conclusión
Congratulations you have a working tablet
Una persona más ha completado esta guía.
SilverDimond
Miembro Desde 09/07/19
109 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 41
Todo El Tiempo: 834
