Saltar al contenido principal
Introducción
If you drop your huion pen and it starts drawing on its own while hovering, it could mean the inner was pushed in and the pen constantly on. This guide will help you adjust the inner as it supposed to be.
Partes
No se especificaron partes.
  1. Remove the buttons first. (use a flat screw driver or something similar) (pic 1) Push the black point down and forward to remove the inner.(pic 2) You will get this(pic 3)
    • Remove the buttons first. (use a flat screw driver or something similar) (pic 1)
    • Push the black point down and forward to remove the inner.(pic 2)
    • You will get this(pic 3)
  2. Kits de Reparación de Batería de MacBook Air
    A partir de $69.99
    Buy Now
    A partir de $69.99
    Buy Now
  3. Use a soldering iron to remove the wire (remember which one goes where.) (pic 1) Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2) Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic  (pic 3)
    • Use a soldering iron to remove the wire (remember which one goes where.) (pic 1)
    • Mark the white plastic and the black one (so you know when to stop when screw it back) (pic 2)
    • Unscrew the white part. Just one or two turns to bring it back to the original position. If you would like to see what's inside, remember which way the spring goes when unscrew the whole thing. It's revrsed in this pic (pic 3)
  4. Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity). Remember to pull the metal up or else the pen won't have power. (pic 2)
    • Put everything back together. Stop the white plastic at the mark. Put the tip on to see if the spring works (the tip moves freely; turn the white plastic back or forth to get a design pressure sensitivity).
    • Remember to pull the metal up or else the pen won't have power. (pic 2)
Conclusión
2 personas más completaron esta guía.
thlong123
Miembro Desde 18/03/18
151 Reputación
1 Guía escrita
Man can I ask you something on google hangouts ? I couldn’t understand some points.
Peace Maker - Contestar
I don't have hangout. Just ask here, I'll try to answer asap
thlong123 -
Why we need soldering iron?
Peace Maker -
To use in step 2
thlong123 -
I suspect this happened to mine but i dont have a soldering iron
Pixeled Forlife - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 Horas: 8
Últimos 7 Días: 48
Últimos 30 Días: 226
Todo El Tiempo: 2,407
