Saltar al contenido principal
How to fix a ripped back pocket of jeans
Qué necesitas
  1. How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: paso 1, imagen 1 de 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: paso 1, imagen 2 de 3 How to fix a ripped back pocket of jeans, How to fix a ripped back pocket of jeans: paso 1, imagen 3 de 3
    • Pin down the ripped portion of the jeans back pocket.
    • Use as many pins as needed to ensure the pocket does not slip from the correct place while sewing.
  2. How to fix a ripped back pocket of jeans: paso 2, imagen 1 de 2 How to fix a ripped back pocket of jeans: paso 2, imagen 2 de 2
    • Thread the needle with the polyester thread.
    • Use about an arms length of thread to ensure that you have enough to sew with.
  3. How to fix a ripped back pocket of jeans: paso 3, imagen 1 de 1
    • Cut the ends of the thread.
  4. How to fix a ripped back pocket of jeans: paso 4, imagen 1 de 2 How to fix a ripped back pocket of jeans: paso 4, imagen 2 de 2
    • Tie a double knot at the end of the two threads.
  5. How to fix a ripped back pocket of jeans: paso 5, imagen 1 de 2 How to fix a ripped back pocket of jeans: paso 5, imagen 2 de 2
    • Start to sew from the bottom of the pocket up.
  6. How to fix a ripped back pocket of jeans: paso 6, imagen 1 de 2 How to fix a ripped back pocket of jeans: paso 6, imagen 2 de 2
    • Remove pins as the needle and thread approaches the pins.
  7. How to fix a ripped back pocket of jeans: paso 7, imagen 1 de 3 How to fix a ripped back pocket of jeans: paso 7, imagen 2 de 3 How to fix a ripped back pocket of jeans: paso 7, imagen 3 de 3
    • Loop the needle through the thread to tie a knot to end and secure the sewing.
  8. How to fix a ripped back pocket of jeans: paso 8, imagen 1 de 1
    • Cut the loose threads to clean up the sewing.
Conclusión
Ashley Dembroski
Miembro Desde 07/19/20
157 Reputación
1 Guía escrita
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 21
Ultimos 30 días: 64
Todo El Tiempo: 3,664
