Saltar al contenido principal
Introducción
The blown element stops the toaster working, but the wires can be rejoined over the blown section, with very little detrimental effect. See this fix in this video guide
Resumen del Video
    • Insert wisdom here.
    • how to fix a toaster
Conclusión
Not too difficult, you need patience though.
4 personas más completaron esta guía.
jon
Miembro Desde 15/05/16
2,281 Reputación
19 Guías creadas
this solution worked great for a bout a two weeks, then despite having connectivity in the ribbon, it does not heat up. It sounded like you weren’t expecting your solution to work forever. Did it give out on you after a little bit because of the increased resistance and the crimp?
mitchell.drury - Contestar
Mine is still working even after all this time (over 2 years ago). If your heater element is still connected (low resistance) then the fault is somewhere else. Trace the resistance of connections back through the switch to the plug to find the fault.
jon - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 27
Ultimos 30 días: 156
Todo El Tiempo: 18,684
