Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
How to fix a Samsung Galaxy S5 that is not charging
Qué necesitas
  1. How to fix a Samsung Galaxy S5 that is not charging, Check Charging Port: paso 1, imagen 1 de 1
    • Note: Images here are from the internet for reference only but not from me
    • Check the charging port at the bottom of the phone. I used a magnifying glass with light to see because these are very small.
  2. How to fix a Samsung Galaxy S5 that is not charging, Check the pins: paso 2, imagen 1 de 1
    • When I checked the pins in my phone, I saw 3. with the one on the rightmost having 2 layers. This was because one of them was bent making it look like there were only 3 instead of 4
    • I used a needle to push the bent pin. After a few pushes, it started charging again!
    • Reminder: be very careful when pushing the pins. I only did this because my phone was not charging at all and I was ready to get a replacement for the charging port if it still didn't work
Conclusión
10 personas más completaron esta guía.
SLomat
Miembro Desde 05/16/18
360 Reputación
1 Guía escrita
1Guía Comentario
Oft genügt es den Dreck mit einem Holz-Zahnstocher rauszukratzen...
Andrea - Contestar Compartir
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 67
Todo El Tiempo: 7,367
